An installation that I am writing requires me to use 2 system environment values: HOMEDRIVE and HOMEPATH, so I've written some Installscript to get the values from the environment and set the values to MSI Properties.
This works perfectly on my XP Professional development and test systems, but when I run the same MSI on a Windows 2003 server, the values come back empty. I've check the server's environment and the values are there and populated.
Further, if I place the Installscript custom action in the UI sequence, the values are returned. It is when I run the custom action in the Execute sequence that the values are empty.
One last bit of information. When the script is run in the Execute sequence, many of the environment variable values are returned correctly (example: logonserver, number_of_processors, OS, Path, PathExt, PROGRAMFILES, SystemDrive, SystemRoot, USERDOMAIN, USERNAME, USERPROFILE, WINDIR, etc.), but HOMEDRIVE and HOMEPATH are returned with no value.
Any idea why I'm unable to get these values from the 2003 server?
Getting Environment Variables
jdm
, May 19 2009 14:40
