hello
in my installer, i have 2 shortcuts.
(1) launch application
(2) uninstall product
all of these works fine. however, i want to show more descriptions to the users when they uninstall the product by using this shortcut.
my short cut has argument as follows:
/x {Product Code}
right now, it shows only this message:
"are you sure you want to uninstall this product"
is there a way to add, at least product name (or image icon), more to this message?
thank you!
add more description to uninstall shortcut
hsong3
, Feb 08 2005 23:32
Posted 09 February 2005 - 09:55
You should be able to change the message in the "text" column of the control table.
Posted 07 March 2005 - 03:51
thank you for the reply.
however, i can not locate this string from the control table (nor the string table)
i think it's located some place else... maybe from the operating system..
where can i find this string so i can modify?
Posted 09 March 2005 - 14:34
/x runs uninstall without the authored user interface. The dialogs and texts you see are coming from the MSI engine and cannot be changed.
