I am trying to convert the Microsoft Firewall Client MSI package to an exe file. I can't get the MSI file to execute with scriptit because I am getting an error message which says invalid command line paramaters. I am running Win2000. I was wondering if there is any way to convert the Firewall Client MSI package to an exe file. Thanks!
MSI to exe conversion
towhoforwhat
, Jul 19 2002 16:18
Posted 19 July 2002 - 16:36
on the subject of converting an msi to an exe you can use the the WISE Package Studio to capture the installation and make an exe. this is called re-packaging and you have to be careful to remove any extraneous captured information from the install.
your problem might be related to the need for a bit of additional information when running the MSIExec from the script. when you doble click on a msi it using the information in the file association to supply these parameters.
does your script use the following type format (without quotes)?
msiexec /I"name of msi here"
it is the /I parameter that tells the MSI Service what to do. this is the minimal requirement...
