Is there a way to tell that the Uninstall is launched from Add/Remove Programs? I use the _IsMaintenance = Remove property if the user goes into maintenance mode and selects Remove but I need to know if the Remove is executed from the Control Panel - Add/ Remove Programs. Is there a property I can check.
Config Control
Detecting the uninstall is executed from ARP
ConfigControl
, Mar 25 2002 22:57
Posted 26 March 2002 - 06:06
I use the condition
and have had no problems with it.
| Code Sample |
| REMOVE~<>"ALL" |
Jamie
The geek shall inherit the earth
Posted 26 March 2002 - 10:00
There is a property SECONDSEQUENCE that is defined in the execute sequence if the user sequence has been run.
Ideally your installation should be able to install and uninstall without any user sequence. I appreciate this is not always possible. However this is greatly appreciated by system admins who need to configure many machines.
Ian Blake
(Currently Unemployed)
