hi,
i was trying to create a installscript msi project .
after bulding the release i tried to run it.
I saw an "intialization dialog" before normal sequence of dialogs appears
I tried to set the property :
Releases ---> small initialization dialog to NO
even then another dialog appears instead of the previous one....
can i customize this dialog or better is it possible to make this dialog in visible
is it possible to remove the setup initialization
Augustuskarthik
, Oct 28 2004 11:11
Posted 29 October 2004 - 14:23
You can't customize it and you can't make it invisible (except in a silent install). You only have the choice betwen "small" and "large"
