Developer will not import a Polish language string table correctly unless installed under Polish OS (though it will then compile correctly).
We had to install a separate version on a Polish OS - and when Developer detected this, across the network, it then refused to start. Catch22 or what?
String table imports fail
ianmw7
, Sep 30 2002 16:58
Posted 01 October 2002 - 09:57
It will detect if two instances of Developer are RUNNING. If you shut down one instance you should be able to start the second instance on Polish OS.
(Note that this might still be a violation of the license agreement... but I'm not a lawyer)
Posted 01 October 2002 - 11:02
That's correct - re running versions. I've contacted IS and asked them what we should do - we can hardly use a Polish OS on a permanent basis, but we do need to prepare releases for Poland.
Ian Murray-Watson
