Hi All,
I'm wondering if its possible to edit an existing MST without having the MSI.
py
Edit MST without MSI?
angp
, Aug 14 2007 08:41
Posted 14 August 2007 - 09:30
Why would you want to do this? If the MSI is embedded in a setup.exe try to run cmd.exe and type in "setup.exe /a" without the quotes and press enter. This will normally allow you to extract the MSI file with the associated source files from the setup.exe file.
