i have built a InstallScript MSI project using InstallSheildX Premier Edition Ver 10. I did not get any errors while building.
But, when i run the setup.exe, the setup is fine till copying files- at this point it terminates giving the following error
"1628: Failed to complete installation"
One or more of my folder levels is 12+, once i remove this folder Java & itz sub folders,then compile & build the setup. Then installation works fine.
I have tried all the other options given in the following url for the above error
http://support.insta...ticleid=Q107319
Eg:
C:\Program Files\WebServer6.1\plugins\java\samples\webapps\i18n\src\samples\i18n\simple\servlet\samplebean
C:\Program Files\WebServer6.1\plugins\java\samples\webapps\jdbc\simple\src\samples\jdbc\simple\servlet
C:\Program Files\WebServer6.1\plugins\java\samples\webapps\security\jdbcrealm\src\samples\security\jdbcrealm
I want to know if there is a limitation on the number of levels WRT to folders ?
-Rashmi
Installtion fails
rashrao
, Oct 01 2004 07:53
Posted 01 October 2004 - 10:02
A verbose log file might give additional clues.
Yes, I believe there is a limit on the folder depth you can install, but I'm not sur eif its documented anywhere.
Posted 01 October 2004 - 11:05
Thanks for the information
I have attached the run time log file with this reply
hope it will throw some light on my problem
-rashmi
-rashmi
Posted 07 October 2004 - 17:38
The error occurs because of the Bug in InstallShield x. Download and install SP1,
it will clear that error.
1-O49KG
Run-time error 1628 no longer occurs during file transfer when an InstallScript MSI installation is attempting to install a deep folder structure.
I got the same error and one of the InstallShield user helped me in solving this issue.
Regards,
Vishnu
1-O49KG
Regards,
Vishnu
