I am trying to build an object in IS 6.31 that supports both NT and 2000 (different files for each OS, but the files have common names).
I create 2 file groups, one for NT, one for 2000. I then create 2 components, one for 2000, and one for NT.
When I build and look at the object using the Cab Vile Viewer, everything is fine, each file group has the proper files. When I embed the object into the calling application, the files become merged, with one overwriting the other.
I thought having two components would prevent this from happening. Is there any way of having two files of the same name in one object?
Same file names, different OS
Jamie
, Feb 19 2003 18:34
Posted 19 February 2003 - 21:44
Sorry, but no idea Jamie. I don't use custom Objects, let alone Objects in general.
I see you're still combating the same basic problem and have given up on ComponentFilterOS.
Posted 27 February 2003 - 12:57
I believe what you are doing is correct.
I use this method for different locales.
I have 8 file groups representing different languages
I then have 8 components for each of the languages.
This is all wrapped up into an object which I call from other applications.
I have not tried this for different OS's but would have thought it works the same.
Posted 13 March 2003 - 20:41
I haven't used custom objects before, but I have done something similar with a DLL. The DLL differed between slightly between 2000, NT, and W9x and we had each dll placed in a corresponding support folder on the installation CD. From there in the install code I used SYSINFO to determine what OS we were installing to and copying the corresponding file in.
For Example:
SYSINFO.WIN9X.bWin95 If TRUE, OS is Windows 95.
SYSINFO.WIN9X.bWin98 If TRUE, OS is Windows 98.
I am sure you can also use something like this to select which of your two components gets installed as well.
For Example:
