Hello,
I have a basic MSI project that contains multiple features and each feature is represented by a Merge Module. Some of the Merge Modules have dependencies on other Merge Modules that are NOT associated with any feature. As you all know, you cannot configure or set the destination of dependent merge modules. Is there a way to get around this limitation?
Thanks In Advance
Dependent Merge Modules and Destination Folder
pikos
, Oct 25 2007 18:27
Posted 29 October 2007 - 17:21
Remove the dependency and add the module manually.
