Using InstallShield X - InstallScript MSI project
I am unable to change the font color in any dialog box in my project. After clicking Edit on the SdWelcome dialog I am able to change the entire dialog pallete's font to a colored font however, when I run the actual setup the font
size is adjusted but the color is not. I do not see any way to do this via script either...
Can anyone tell me how to change the font color for a (customized) dialog? I actually need to change just one text box in my dialog, however I would settle for anything at this point.
Mike
Font Colors for Dialogs
mh8368
, Jul 12 2004 19:08
Posted 13 July 2004 - 01:47
I have never used this feature, but it may be that Installshield heeds the color defined by the operating system. Try changing the color of the OS font and see if this affects your setup.
Posted 13 July 2004 - 08:55
In a InstallScript MSI project I think you need to call some Windows API in the dialog processing script to change the font color, similar to how you would do it in C.
For Basic MSI it's much easier.
