We have had our software and installation translated, and the instalation has been generated by the translating company, but they have included the wrong version of one the files.
Is there any tool that will allow us to remove the wrong version from the CAB file, and put the correct version in the CAB file in it's place? Both files have the same name so that side of things shouldn't need changing.
Editing CAB files
RichardB
, Apr 26 2001 10:32
6 replies to this topic
Posted 27 April 2001 - 04:24
That's impossiable, InstallShield CAB files' format are different from Microsoft Standard CAB files, so there's no way to edit it.
Posted 27 April 2001 - 08:48
Later versions of IS5 include a command line tool to update CAB files in InstallShield format (iscab.exe)
Posted 27 April 2001 - 08:54
I found, and have tried ISCAB.
I could get the list of contents without problem, but when I tried to remove the offending file it died with an error:
G:\temp>iscab data1.cab -id1.ini -r
Error: Internal error in file DiskImage.cpp, line: 35
The system cannot find the path specified.
This was trying to edit a German CAB file with ISCAB from the English version. Are they language coded?
Posted 27 April 2001 - 12:49
I found that iscab.exe would work if I ran it when in the installshield programs directory, and referred to all other files by full path.
Many thanks for your help.
