The file in question is a .ini file that is 68,000k in size.
Thanks-
Thomas
Posted 21 August 2001 - 19:54
Thanks-
Thomas
Posted 22 August 2001 - 12:55
So there will be no problem editing a large ini file if the lines are not larger than a thousand letters (and spaces and ...).
Posted 22 August 2001 - 16:16
When I use the FileInsertLine, WriteProfString or ReplaceProfString with an unedited version of my .ini file, the functions fail. There are lines in the .ini that are very long, but the lines I am replacing are well under 30 bytes long.
When I remove the lines from the .ini file that are very long, the functions seem to work correctly.
So what I need to know is how do I write to these files if the lines exceed the limits?
Posted 23 August 2001 - 13:06
btw: posting the problem twice returns less than twice the number of answers ...
