I'm adding ODBC to my server installations. Under our new version of software, all the system DSN connections protocols are listed as "Other". What's odd about this is that the previous version of the installer would automatically set them to TCP/IP. I've check my host machine(where I do my builds), all of these connections are listed as TCP/IP. Now the previous version of our installer was first built using a 5.x version of InstallShield. The newest installer started as 6.x (InstalledShield)and is now 6.3.
Now on to the question: Is there a way to force an ODBC to use TCP/IP?
Setting Protocols for ODBC
Xitch13
, Jun 13 2002 17:37
Posted 13 June 2002 - 17:37
Posted 27 June 2002 - 20:21
Solved my own problem by playing with the registry. When in doubt - hack. I used the following command to Change the registry of MS SQL Server
Note: You'll have to set the default root to HKEY_LOCAL_MACHINE before you issue the above comman
Code Sample |
RegDBSetKeyEx("Software\\Microsoft\\MSSQLServer\\Client\\ConnectTo", ".", REGDB_STRING, "DBMSSOCN, .", -1); |
