Installing System Files
Posted 30 May 2001 - 20:39
Posted 31 May 2001 - 09:20
Populating these table is the correct way to register programs.
Msi packaging programs such as InstallShield have functions that will extract registration information for you. These functions are not perfect so you may need to add a few registry keys yourself.
Posted 31 May 2001 - 17:13
Posted 31 May 2001 - 23:29
In one of my installations I had eight objects seven worked without a problem. The eighth was a shell namespace extension. Installshield failed to spot the shell keys being made so I needed to add them manually. Not really a problem but you need to check you installation carefully preferably on a clean machine to make sure registrarion is complete and correct. Once it works once you can be reasonable sure it will continue to work.
Posted 31 July 2001 - 17:46
