I read the following article, "How do I add HKEY_CURRENT_USER registry entries to all profiles?"
How do I remove HKEY_CURRENT_USER registry entries from all profiles?
Removing Registry Keys
snowc9901
, Oct 26 2005 19:55
Posted 27 October 2005 - 13:00
This would require a custom action that loads all the user hives into registry and deletes those entries. In genreal such entries are considered user data and should be left behind.
Posted 02 November 2005 - 16:59
Hi All,
Yes,you can install HKCU registry for each user if you can make one of those HKCu reg as a key path and you are having a advertise entry points in your package.
But it is not possible to remove HKCU reg and userdatafiles from each user profile during uninstallation.
Mayur
Mayur
