When building a project the following error is displayed:
Warning -4352: There is no key file for feature ScannedProject. A key file is required for dynamic COM extraction.
After which although all dll's are installed, they are not all registered. (Namely DAO360.dll) Can anyone let me know what is wrong?
Warning -4352
Julianse
, May 14 2002 09:31
Posted 07 June 2002 - 13:33
I had this same problem when building an install for an ActiveX executable that I developed. I believe the problem occurred when I moved all of the source files (including the project file), relinked the files in InstallShield, and then re-built the project. To solve the problem, I simply scanned the project again. This creates a new ScannedProject file group. Just make sure it contains the same files/file links as the old one, and then delete the old one. Hope this work for you.
Dan Palmer
dcpalmer@praxiseng.com
Dan Palmer
