Hello,
Can I set the value of a control ( e.g. the Static control for Space Required ) within a Dialog Box created with, e.g. SdComponentDialog?
I am also trying to use a resource from IsRes.dll to copy the dialog created with SdComponentDialog, but, instead of Check List Box I have a Static control.
How can I find this Dialog? Do I have to create it by myself?
Thank you.
Uninstalling
Ioana
, Dec 20 2004 13:28
Posted 21 December 2004 - 09:38
If you want to set static textx at runtime you need to modify the script that handles that dialog. Not sure if the script for the standard dialogs are included in your version (they used to be in older versions)
Posted 21 December 2004 - 10:04
Thanks for the answer.
But how can I modify this scripts if they are not included in my version?
Reagards.
Reagards.
