Hi
I need to generate a patch and I am using patch tool msimsp.exe to create the patch and found that the patch is not proper though created successfully.
Command used
"MSIMSP.exe -s patch.pcp -p " & "patch.msp -l patchcreation.log"
This creates a log but it doesnt generate any errors in the log file about the Removal of files .
But when I build the same patch using Installshield it creates a build log andgives the following errors and later I found that some of the files are deleted in the latest package .
ISDEV : error Val0006: the component is missing in the newer version of the setup.
How to generate the same errors in patch log using msimsp.exe?
Lakshman
Patch Validation errors
jhlakshman
, Jun 05 2012 14:31
Posted 06 June 2012 - 16:35
InstallShield has some validation tools that the SDK tools don't have.
Posted 08 June 2012 - 11:17
Thanks for the reply Stefan. Is it possible to use the Installshield tools to generate the same set of error validations using commandline?
Posted 09 June 2012 - 11:48
I'm not sure if validation can be performed from the command line if it's not an InstallShield project. I don't think it validates the .msp or .pcp but it compared the two msi files to detect that a component has been removed.
