Our Requirment:
1. Check if D: drive is present or not.
2. If present, then copy files into D:\Folder1 or else into C:\Folder1
I tried copying files using Files & Folders section. But there was no way over there to acheive the desired conditional copying.
Pavan
Copy files into D drive or C drive based on availability of D drive.
PavanKumar1234
, Sep 12 2013 09:02
Posted 12 September 2013 - 09:02
Posted 06 December 2013 - 06:22
Hi Pavan,
One thing you can do.
You can access registry HKEY_LOCAL_MACHINE\SYSTEM\MountedDevices
Here you extract value \DosDevices\D:
if it present means you can copy to D drive.
For runtime copying you see FeatureSetTarget() in installshield Help.
