Anyone have any experience setting service dependencies at runtime? I figure the way to do it would be to update the msi db ServiceInstall table with dependency info based on installed components? Ideas?
NT Service Dependencies
tmulcahy
, Oct 30 2001 18:32
Posted 05 November 2001 - 15:19
I am not quite sure if a understand Your question correctly. You like to install a service and like to set the dependencies for this service according to some condition evaluated at runtime: Then I would use properties which You can set at runtime in the view "Install services" and the line Dependencies in the InstallShield IDE.
Barbara
Posted 06 November 2001 - 16:02
You understood correctly! :-)
I figured it out. The way I did it was by using conditional components, based on properties set at runtime, via a radio button control dialog. Thanks for your input!
