Hi !
In IS 5 it was possible to change the system variable SELECTED_LANGUAGE and to start a second setup program using a different language.
In IS 6, the same code fragment does not compile but returns a syntax error. For me it seems that this variable can no longer be modified within the scripts !
Is there an alternate possibility to modify this system variable or even an alternate way to launch a second setup with a different language ?
Thanks in advance
Michael
SELECTED_LANGUAGE
seagum
, Oct 14 2002 14:23
Posted 15 October 2002 - 20:26
You can try the -l parameter. Not sure if it will work for sub installs launched via DoInstall
