Dear all,
I have a problem. I'm use Basic MSI Project(InstallShield Dev7 sp4).
I'm want to know maintenance result on installscript.
so, I'm write a script belowing:
if (MAINTENANCE) then
endif;
but, the result=0 when I'm choice install or remove..,etc
Why does the result not (true or false)?
Please help me. Thank you very much.
MAINTENANCE result=0?
kwansho
, Sep 21 2003 17:31
Posted 22 September 2003 - 09:16
I believe that MAINTENANCE will only work in a InstalLScript SMI project, but not in a custom action in Basic MSI.
Posted 22 September 2003 - 10:55
| QUOTE (Stefan Krueger @ 2003-09-22 08:16) |
| I believe that MAINTENANCE will only work in a InstalLScript SMI project, but not in a custom action in Basic MSI. |
Thank you, Sir:
If I want to know MAINTENANCE value in MSI .
How do i do ? Could you tell me if you have other solution?
Posted 22 September 2003 - 17:25
You can use the Installed property. It will not exist on first time install.
