During the course of installation the script opens a file name 'Autobuild.bat' and adds lines. These lines are the path to a second batch file and the path to delete the shortcut to autobuild. On reboot there is a shortcut in the common list to run "<TARGETDIR>/Autobuild.bat" (the quotes are included in the shortcut but have also tried it without them). This shortcut is called, unfortunately it runs two copies of the autobuild. The first is Autobuild.bat and the second Autobu~1.bat. This only happens on Win98 machines! Is there a way to run this only once?
Batch file runs twice
Xitch13
, Jul 23 2002 15:00
Posted 23 July 2002 - 15:00
Posted 26 July 2002 - 15:50
i'm thinking that a quick solution to this would be to limit the BATch filename to an 8.3 format. say, rather then use the AutoBuild.BAT name use the AutoBld.BAT ?
Posted 26 July 2002 - 16:01
Not sure that would work. I created a small test installer that only installed 2 BATch files and a shortcut in the Start-Up folder. On reboot the shortcut would run a BATch file named Test.BAT which would then call the second BATch file. On a Win98 box, Test.BAT would run twice.
Thanks for the suggestion.
