What is necessary for an MSI in order to install correctly either on Windows 2000 Terminal Services or on Citrix MetaFrame?
I understand that feature states 0x0001 and 0x0004 are forbidden and that ALLUSERS=1 should be set (of course). Additionally, some tests on Citrix indicate that it is advisable to set DISABLEADVTSHORTCUTS=1 (in order to prevent the MSI engine from being faster than terminal server's own mechanism providing the HKCU data for a new user, which would result in an attempt to install the HKCU-component, which in turn is forbidden).
However, I really don't know if the conditions above are sufficient for all cases.
Terminal Services
JKHemker
, May 09 2001 11:27
