I have version 1.0 of a product which has feature A and feature B. There is version 2.0 of the same product which only contains feature 2. Feature A is deleted in this new version.
I install both the features as part of Version 1.0. Now, i do a MAJOR UPGRADE from version 1.0 to 2.0. Will the feature A get uninstalled as it is not part of version 2.0?
Delete a feature in a Major upgrade
aarthi_m
, Nov 29 2007 16:31
Posted 30 November 2007 - 15:10
Yes, a major upgrade does an uninstall and then an install, so your obsolete feature should be removed.
Kathy Morey
Synergy Software Engineer
kmorey@profitstars.com
Posted 30 November 2007 - 15:37
Yes it should.
Posted 03 December 2007 - 08:03
Thanks for the reply. Is there a way of avoiding the uninstall of the obsolete feature?
Posted 07 December 2007 - 18:23
Another option would be changing the Major Upgrade settings. If the "Remove" column in the "Upgrade" table is empty, all features will be uninstalled. You can instead enter a comma delimited list of the features that should be removed during the upgrade. This will however leave the old versioon listed in Add/Remove Programs control panel because the old version is still partially installed.
