I created a dialog with an edit box.
The property of edit box is 'PROP1'.
A pushbutton on the same dialog call a CA with DoAction event which changes the property 'PROP1'.
How can I update the edit box?
Update Edit Box after DoAction
mgraefe
, May 15 2001 14:40
Posted 16 May 2001 - 00:08
You can get this to work by creating a duplicate dialog. After the DoAction, you load the new dialog, which will display the updated value of PROP1.
To the best of my limited knowledge, there is no way to refresh values without reloading a form.
Posted 22 May 2001 - 14:17
Create a CA which change the value of a Property ( 'TEXTEDIT' by example)
In the dialog behavior of your button,call your CA and
after, add this line :
Event Argument Condition
[PROP1] [TEXTEDIT] 1
It works well with my setup so...
Posted 11 April 2002 - 10:11
Thanx for your help man! Your sollution is the only good one. The duplicate dialog is so lame ...
Thanx!
Thanx!
