I would like to set TARGETDIR to C:\Mike (or whatever). How do I do that?
My own directory
micand
, Apr 30 2001 16:54
Posted 01 May 2001 - 00:53
You can set the default target directory by changing the destination folder under General Information/Product Properties. There you can set it to be whatever you want, although it isn't recommended to hard code it to a specific drive.
Posted 01 May 2001 - 17:29
If you are installing from the command line, you can add the desired setting of TARGETDIR as a command line argument. Check the article on command line arguments in the Windows Installer SDK for further information.
