ERROR: Wizard bean place holders must be resolved before building
However I do not get this error if I build the same project from the GUI. I'm stumped -- what does it want? Is there a workaround?
Posted 29 January 2002 - 22:03
Posted 31 January 2002 - 17:18
In otherwords, somehow when you launch ISMP from the command line, you are getting a different class path than when you launch the IDE.
Are you using 4.51? Of course if you are still uning 4.0, then you have to manually specify the classpath no matter what, and it has to include installshield's jars and your custom beans.
No matter what version you are using, and no matter what is causing you to use a JVM with the wrong classpath to launch ISMP from the command line, if you are getting the wrong classpath, you could try specifying the classpath manually.
There is a file in the directory where you installed ISMP called LAUNCH.txt and it describes how to specify the classpath when you launch a command line build. With 4.51 you shouldn't have to specify the classpath. See if it works when you manually specify the classpath and be sure to include the directory with your custom beans.
I really think the problem has something to do with your somehow using a JVM with a classpath that doesn't include your custom beans when you are trying to launch ISMP do a command line build.
Anyone have any idea what strange configuration of JVMs/installshield development environments could have been done to cause this?
