lFreeSpace = GetDiskSpaceEx ( svResultPath, MBYTES );
if (lFreeSpace < 0) then
MessageBox ("GetDiskSpace failed", SEVERE);
// else
//SprintfBox (INFORMATION,"", "%ld KBytes free on drive %s.",
// lFreeSpace, svResultPath);
endif;
lTotal = 20;
if lFreeSpace < lTotal then
SprintfBox (SEVERE, "Disk space!", "Not enough disk space found.
"Need atleast %ld MBytes free", lTotal);
abort;
endif;
GetDiskSpaceEx & Novell Systems
Blackdog
, Jul 11 2001 18:57
Posted 11 July 2001 - 18:57
I have the following code in our script. One of our users has a Novell dedicated server with a Win95 workstation. This user keeps getting the message not enough disk space even though they have 21 gbytes left. Is this a known problem with GetDiskSpace and Novell? Will InstallShield 6 solve this?
Posted 12 July 2001 - 07:36
The problem may be Novell, but it may also be the Windows 95 version. GetDiskSpaceEx internally calls the Windows API function GetDiskFreeSpaceEx, which is not supported in versions of Windows 95 earlier than OEM Service Release 2.
You can check whether the target operating system supports GetDiskFreeSpaceEx by using script code like the following:
prototype BOOL KERNEL.GetProcAddress(HWND, STRING);
// GetModuleHandle should already be prototyped
if GetProcAddress ( GetModuleHandle("kernel32.dll"),
"GetDiskFreeSpaceExA" )!=0 then
nFreeBytes = GetDiskSpaceEx ( "C:", BYTES );
else
/* If GetDiskFreeSpaceEx is not supported,
call GetDiskSpace instead of GetDiskSpaceEx. */
nFreeBytes = GetDiskSpace ( "C:" );
endif;
