Hi there!
I'm working on a tool for automated creation of our ISM-Projects. Most of the needed interfaces or access function are available, but some are missing:
- File type registration
- Shortcut properties or shell properties for shortcuts
- Dialog manipulation for the installation UI sequence
(If you found more, please add)
The only way to solve this for me is doing the following:
- Creating the project file using the COM automation interface
- Doing all the stuff which is supported by the interfcae
- Setting the project file format to XML
- Saving and closing the project
- Opening the project file as a XML document
- Adding all missing data to the table definitions
- Saving the XML file
- Reopening the project via COM
- Setting the project file format back to binary
Does anyone have a better idea for this? What do you think about my solution?
Greetings
Meg
