I am facing an issue while performing administrative extraction of an msi file. I am using "msiexec.exe /a <msi file location> TARGETDIR = <extraction location>" command to perform the Administrative extraction. The msiexec.exe is throwing back an error, which reads "Error 1304. Error writing to file <file name>. Verify that you have access to that directory".
I have cross checked several time for the access writes and things seems to be correct, as I am able to extract any other installer in the same location.
I know that the file name (mentioned in the error) is more than 255 characters of length. The Installation of this file is happening properly, but the administrative extraction of this installer fails with the above mentioned error.
Can somebody give suggestion, on how to extract the file out of the msi just using command prompt ?? (without performing an installation).
Thanks in advance ![]()
