i need to add several DSNs into my project...
So i added it into my project by using the ODBC Resources... (not Component View)....but wat i found is, these DSNs r not removed once i uninstalled the package...?? i checked the Help for ISWI, it is documented that we can choose either to delete DSN or not somewhere, but where ? i can;t find any related check boxes or watsoever to select this options....
hence, i tried another method, to create it in the Component View, this time different, you might have to installed with ur DSN file, says a Access file together with the DSN, i did it.
but i found that the DSN is not installed or configured in my computer....the Access file is there of coz....
so, may i know how can i create my DSNs in a proper way with the ability to remove it when i uninstall my application ??
Thanx for every brilliant ideas !!
