I am working with a large installer project that was presumably created with a wizard.
Is there any easy way to remove the Yes/No reboot dialog from the end?
THERE are several public properties that look related:
ISSCHEDULEREBOOT
ISREBOOTREQUIRED
And a private variable:
RebootYesNo
Searches through the tables show many references.
Any easy way to do this?
Removing Reboot Dialog?
cmahood
, Aug 19 2004 22:45
Posted 20 August 2004 - 13:06
Do you want to suppress the reboot, or do you want the reboot to happen without confirmation?
Posted 20 August 2004 - 16:40
I want to suppress the reboot, it is not needed.
Thanks for responding, I experimented and found that by removing the Schedule Reboot Custom Action AND the Reboot Required dialog that a reboot is not requested.
Posted 23 August 2004 - 13:25
Please double check. Usually InstallShield would not reest a reboot unless it is necesssary for some reason.
