Simply put I want to display an OptionList (using SdAskOptionList) without any defaults to force the user to select one before he can press NEXT.
The idea is to provide a list of options to the user but have the NEXT button disabled until at least ONE of the options are selected - which in turn means that when we first display the list none of the options should be selected...
SdAskOptionsList() without defaults [ISPro 6.31]
Shaitan00
, Oct 23 2006 19:14
Posted 23 October 2006 - 19:14
for nCurrent = 0 to nSize // ... do some work to get sValue corresponding to this nCurrent ... ComponentAddItem("CustomSetNameList", sValue, nCurrent, FALSE); endfor; Disable(BACKBUTTON); Disable(NEXTBUTTON); sTmp = MEDIA; Disable(DIALOGCACHE); MEDIA = "CustomSetNameList"; nRetVal = SdAskOptionsList("Step 5 - Identification", "Please select the"+ " proper name.", "", EXCLUSIVE); MEDIA = sTmp; Enable(DIALOGCACHE); Enable(NEXTBUTTON); |
Root problem is - during install sometimes people just click next,next,next,etc... but at this stage I want to FORCE the user to select something from the list.
Therefore I need to ensure there is NO default and I need to ensure that the NEXT button is disabled until one of the options are selected...
I can't seem to figure out what is wrong with my above-code, I did some reading and I thought that setting "ComponentAddItem("CustomSetNameList", sValue, nCurrent, FALSE);" when adding the value to the Component would solve the DEFAULT problem (as bSelected is FALSE for all items) but this doesn't seem to work, when I run it the 1st option on the list is always checked...
Any help would be greatly appreciated...
Posted 25 October 2006 - 02:24
I played around with your code and it seems that the exclusive setting on a dialog listing will always force the first option to be selected.
With the nonexeclusive setting enabled, it works as would have expected. Especially since you state that more than one option can be selected.
If you must use the exclusive setting though, then I guess you'll have to include a dummy initial value to workaound that limitation.
