Since the Uninstall\[ProductCode] registry key has nothing to do with uninstalling, WHERE or HOW CAN I CHANGE THE UNINSTALLSTRING???
How to use a custom uninstall
Cygnusx1
, Oct 25 2001 14:52
Posted 25 October 2001 - 14:52
We NEED to launch Microsoft's SMS Advertised Program Wizard when the user clicks on remove from the Add/Remove Programs. Our environment is "locked down", meaning the user has to have Admin rights to install & uninstall. Installing is no problem. Uninstallation must be started from the SMS control panel.
Posted 25 October 2001 - 15:50
Are you aware of the ARPNOREMOVE property. If you create this the program could not be removed with add remove programs and an alternative method must be used.
