Looking for token pasting.
In C I would use ##
Like:
int var1 = 6;
int num = 1;
// prints 6
printf( "%d", var##num );
// The ## takes the value and pastes it to the name
// so var##num essentially becomes var1
Can this be done in installscript?
Bascially I have a string ("VAR=5")
and I want to parse and get
"VAR" and "5"
And then somehow set the variable named VAR to be 5
VAR=5
how?
Token Pasting
mikejobu
, May 10 2008 01:34
Posted 11 May 2008 - 17:52
No, I don't think that's possible, unlesss you resort to an array, something like:
var[1] = 6;
num = 1;
Sprintf(svString, "%d", var[num]);
var[1] = 6;
num = 1;
Posted 11 May 2008 - 22:21
| QUOTE (Stefan Krueger @ 2008-05-11 17:52) |
| No, I don't think that's possible, unlesss you resort to an array, something like: var[1] = 6; num = 1; Sprintf(svString, "%d", var[num]); |
No - cant do it by array.
Ok - I figured it was a little to advaced for installscript - altho there is some way to access the variable names via a stack as the debugger does it...
Does anyone know of how to simply access the namespace of the variables defined globally?
Again - prob too advanced to find this info anywhere - I will play a bit and see.
Thanks!
