(Edited by akin smith at 2:11 pm on Mar. 28, 2001)
Registry Binary Values
akin smith
, Mar 28 2001 14:09
Posted 28 March 2001 - 14:09
does anyone know if there is a known issue with WI v1.1failing to write binary registry values? I get the error 1406, "cannot write the key..... verify that you have sufficient access to the key...". I have also noticed that Wise for WI v2.01 fails to faithfully record binary registry values during setup capture, but appears to edit the them into some abbreviated string value. Is there a way around this? Many thanks for your comments (eagerly awaited!)
