Hi friends,
I had created a basic MSI project using VbScript. I had included a property called "TEMPPATH" to retrieve the tempfolder path. I run my product in Windows Server 2008 operating system.
I found the value of the property "TEMPPATH" is retrieving the correct value in case of GUI type of installation(It included the special folder also(temp/1). Where as during Silent mode of installation, the value is not retrieved correctly. During silent installation its not acquiring the current session and the property "TEMPPATH" is neglecting the special folder(till temp only).
Can any one help me why this behaviour occurs only in silent mode of installation.
Thanks in advance
TEMPPATH property in silentinstallation
Srimathy
, Jan 06 2010 07:54
Posted 19 January 2010 - 12:12
In silent installation, the GUI sequence is skipped.
You can schedule the Vbscript action in Execute sequence also along with UI sequence.
May be you can provide more details as to how you are retrieving the TEMP folder. What type of Custom Action, where are you scheduling it etc
Posted 19 January 2010 - 16:47
Hai dsailesh,
Thank you. I had retrieved the TEMPPATH using GetSpecialFolder API. And i had added an immediate customaction for executing in execute sequence. Now the problem has been resolved. Thank you somuch:-)
