Thank You
Barbara
Error 2318 during installation on a terminal server
Barbara
, Oct 08 2001 07:18
Posted 08 October 2001 - 07:18
My setup installs fine on Win2k Pro, NT4 etc. Now I am trying to install on a terminal server (via Add/Remove software) and the setups end directly after the user sequence (when hitting install now). In the log-file I see error 2318, which means the source msi-package can not be found. I was logged in as a local administrator, who has all rights on the directory where the source package is located. So I think, this is a follow up error. Has anybody a suggestion where to look ?
Posted 15 October 2001 - 08:38
Solved the problem: It was a problem of user permissions. Even that I was logged in as a local administrator and the user rights seemed to be OK on the directory, I had not the right permissions. I created a new directory, copied the setup there and the installation worked fine.
Barbara
