I have 5 .dlls and 3 com .exe's that must not be unregisterd if the shared ref count is above "1".
I have been looking for a while and tried some logic in the help file but have not been able to get it to work.
If anyone has some sample code that will do this i would really appreciate it.
Here is the logic i think i need(tell me if im wrong)
HKLM\software\MS\windows\Currentversion\shareddlls
<<key >> type value
c:\test\test2\foo.dll REGDB_DWORD 1
c:\test\test2\foo2.dll REGDB_DWORD 1
c:\test\test2\foo3.dll REGDB_DWORD 1
c:\test\test2\foo4.dll REGDB_DWORD 1
c:\test\test2\foo5.dll REGDB_DWORD 1
If the value of foo.dll in HKLM\software\MS\windows\Currentversion\shareddlls
\ is 1 or lower then unregister
if not, leave it be.
Basically i need it to unregister the above 5 files if the shared ref count is 1 or lower but not if its 2 or higher.
Im sooo lost.
Please help.
need help with logic on this uninstall ....
Adam
, Jul 27 2002 02:06
Posted 28 July 2002 - 03:50
You've kind of got the right idea Adam. However, if these files were self-registered as a part of the file group transfer, then this will be auto. handled by the uninstall. The reference count will be automatically decremented by one and if the new value is zero, then the user is prompted to remove a shared file.
If this is not the case, then you will need do it manually. To do so, you should get the value from the registry, converted the resulting string value to a temp. number variable via StrToNum, and decrement it. If the previously decremented value is zero, you should unregsitry the DLL via the command "regsvr32 <path>\<filename> /u" where 'u' does an unregistration. If the value is not zero, then you should convert it back again via NumToStr, and write the new value back out to the registry. That way future uninstalls will have the appropriate information.
Hope it helps.
Hope it helps.
Posted 29 July 2002 - 21:12
well i have to do it manually.
I cant seem to get RegDBGetKeyValueEx to retrieve anything.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDLLs
Type: REG_Dword
Value: 2
How do i get that value ?
Everytime i try RegdbGetkeyValueEx it doesnt get any number.
Type: REG_Dword
Value: 2
Posted 29 July 2002 - 21:30
Well this seems simple enough. It seems like alot of applications would have to do this.
Can anyone help?
If i cant get this figured out by thursday ill have to fork over $100 and call installshield.
Basically i just need,
Anyone that can help me save a hundred dollars, i will love forever
Can anyone help?
| Code Sample |
szkey = \\software\\microsoft\\windows\\currentverison\\shareddlls szName= TARGETDIR + "\\foo\\foo1.dll" nvType= REGDB_NUMBER svValue = ? nvSize = ? if (RegDBGetKeyValueEx (szkey,szName,nvType,svValue,nvSize) = 1 then Unregister the .dll in szName else just decrement the value of szName by 1 |
Posted 30 July 2002 - 00:35
You forgot one vital piece of information. If you compare the registry path and your code, you'll noticed that the reference to HKLM is missing!!!
This is because before registry call(s) you need to explicitly state what area you'll be searching. In your case:
RegDBSetDefaultRoot (HKEY_LOCAL_MACHINE);
Besides that, in looking at your sample code, the szkey value should be in quotes. I also normally don't include the initial \\, so you may need to get rid of those. In addition, it's better to use ^ over + as the former automatically takes care of any extra or misses backslashes, so you should change the assignment of szname to be TARGETDIR ^ "foo\\foo1.dll". Finally, all of the lines of your code are missing semicolons, but I'm sure that's just because this is a sample.
However, that should get you going. If you have any additional problems, just let us know.
Now about that $100, I'll not a greedy person, so I'll just take half of it. You can keep the rest.
