I haven't used IS for many years, and I'm just trying to add an additional object to and exisiting 6.31 project. What I need to add uncompressed setup that is already a binary setup.exe that immediately installs a printer driver. I don't think it was made by using IS.
The documentation seems to indicate that I should create an object project and add the file to that, and then add the object to the existiing setup. I made the object, but I haven't put any code into its script because I don't know how to get it to install itself and from where. I'm also not sure how to kick off the object from the setup.rul in the existing project.
I don't have any need to read or write any properties to this simple object. It's just a another setup.exe and I want to say "GO".
I suppose I could maybe using LaunchAppAndWait and just add a checkbox and forego the whole "object" adventure if that would be better.
I think I need sample code that shows me how to do it either way.
How to run a setup from inside an IS setup
wayneo206
, May 23 2006 23:33
Posted 24 May 2006 - 00:24
Yeah, I'd recommend not bothering with the object and just use LaunchAppAndWait like you said.
You can enclose the setup either in the project's special setup files -or- a standard file group, and then use the following IS script when appropriate:
| nResult = LaunchAppAndWait(<FilePath> ^ "setup.exe", <Switches>, WAIT); if (nResult < 0) then MessageBox ("WARNING: Unable to launch '"+ <FilePath> ^ "setup.exe'.", WARNING); endif; |
Edited by Taco Bell, 24 May 2006 - 00:34.
