Hello,
I am looking for a way to store the Username and Password data for a user created with the sdLogonUserInformation dialog in string variables for later use (XML file manipulation for impersonation settings).
Could anybody enlighten me on how to retrieve said information when/after the user clicks "Next" in the dialog?
Thanks a million,
Felix
Extract Data from sdLogonUserInformation
ftk
, Oct 10 2005 21:41
Posted 11 October 2005 - 09:44
It is returned in the third and fourth parameter of the SdLogonUserInformation function. If you don't see it in your script you may need to add the OnFirstUIBefore event handler to your setup.rul.
Posted 11 October 2005 - 14:45
I looked at the prototype for the function and apparently the user name and password are send BYREF. Should've thought of that earlier.
Thank you for your reply!
-Felix
-Felix
CODE |
external prototype SdLogonUserInformation(BYVAL STRING, BYVAL STRING, BYREF STRING, BYREF STRING); |
