When I try to capture the setup of InstalShield Developer 7 I don't get the username, company and serial key. And the program will ask for the serialkey the first time the user starts the developer. I have tried to monitor it too, but I can't figure out what it is? does anyone know what to do?
Why can't I capture username and serialkey
dannyb0y
, Jun 24 2003 13:31
Posted 24 June 2003 - 15:50
Are you talking about the setup of the Developer 7 tool itself? I believe it was created using the InstallScript MSI project type. Therefore you'd have to record a .iss response file.
Posted 25 June 2003 - 06:48
I have recorded an iss, but the setup cannot run in silent mode, the setupprocess only run for a few seconds and after that it ends and nothing is installed.
I have modified the msi with userName and PIDKEY properties, but I think setup.exe does something to set the serial and username.
I have also tried to do a setupcapture usin wise packagestudio 4.5, everything except serialkey and username is captured.
Any ideas???
Any ideas???
Edited by dannyb0y, 25 June 2003 - 06:48.
Posted 25 June 2003 - 08:09
Maybe the serial key is not recorded in the .iss. This may be the intention or an oversight by the setup author. there's nothing you can do in this case. I recommend you contact the vendor for advice (or upgrade to Developer 8 which uses pure MSI and doesn't require an .iss file)
On the other hand, maybe the serial key is not the real cause for the setup failure. Generate a log file to see where and why it aborts.
