hello everyone
i create a custom dialog (using DefineDialog and OpenFile function). however, i can not open and display rtf file format.
how do i display read-in informations from other than a text file???
thank you
using script to display rtf file
hsong3
, Jul 19 2003 18:27
Posted 22 July 2003 - 11:15
Take a look at sample "RTF License Dialog for Standard Projects" at http://www.installsi.../en/msi/isd.htm
Does that help you?
Does that help you?
Posted 23 July 2003 - 00:46
thank you for the tip.
however, i can not use the script in the sample project, "RTF License Dialog for Standard Projects", in basic msi project.
is there some restriction about win32 functions when it runs in basic install shield project????
Posted 24 July 2003 - 20:48
Sorry, I didn't notice yu are using BasicMSI.
Can you elaborate on how and where you are calling DefineDialog and OpenFile? Is there a reason you're not using the ScrollableText control to display RTF content?
Posted 01 August 2003 - 14:42
thanks for your replies. however i fix this problem by using C. ^^;;
i needed dynamic display option for RTF because i have 2 different license agreement documents and i tried to avoid rebuilding the setup second time.
again, thank you for your kind replies.
