I am using schedule reboot in msi project in Execute sequence after Launch condition.
Required out put is:
Mandatory display of Dialog for reboot at the end in case of Install/repair/upgrade
No display of Dialog for reboot at the end in case of uninstall
I tried following conditions but getting wrong output as given below:
Not Installed [OUTPUT: dialog at the end of install only]
NOT Installed OR (Installed And ACTION<>"INSTALL") [OUTPUT: dialog at the end of install only]
NOT Installed And ACTION="INSTALL" [OUTPUT: dialog at the end of install only]
((NOT Installed) And (ACTION="INSTALL")) OR UpdateStarted [OUTPUT: dialog at the end of install only]
Not Installed OR (_IsMaintenance = "Reinstall") [OUTPUT: dialog at the end of install/ uninstall/ repair/ upgrade]
Not Installed OR (_IsMaintenance = "Reinstall" And _IsMaintenance <>
"Remove") [OUTPUT: dialog at the end of install/ uninstall/ repair/ upgrade]
Not Installed OR (( _IsMaintenance <> "Remove") OR (_IsMaintenance =
"Reinstall")) [OUTPUT: dialog at the end of install/ uninstall/ repair/ upgrade]
Not Installed OR (( _IsMaintenance2 <> "Remove") OR (_IsMaintenance1 =
What condition I should use to get correct output ??
Edited by epriya2003, 21 February 2006 - 19:02.
