I see you can pass an arguement to a Service start. Is there any way to pass a parameter to bypass an error, Can't Start Service, for example?
Starting a Service - Ignore Errors?
Superfreak3
, Apr 04 2003 22:35
Posted 14 April 2003 - 13:56
The problem was that my service start was erroring on systems with no sql database.
The problem was that I had the install level set to low on the feature containing the install/control service features. Once this was set accordingly, the service would not be installed and the control event not attempted unless feature installation conditions were met.
Problem solved.
Sorry if I wasted anyone's time.
Problem solved.
