I am trying to compile a script (setup.rul) using the InstallShield Script Compiler v3.00.071. The odd thing about this is that it will compile this file correctly on a coworker's pc (Win95) but it fails with the following errors on my Win95 pc (1008: 'PROGRAMFILES' Syntax error. Unexpected token encountered." and "1008: 'FOLDER_STARTMENU' Syntax error. Unexpected token encountered." Unfortunately the coworker no longer works here so I can't ask if he has made any customizations of the compiler program. Can you help me? Do you have any suggestions on how I can fix this, barring installing a newer version of the InstallShield software?
Run-Time error 1008
kfraser
, Feb 26 2002 22:28
