Does anybody know if it is possible to change a component attribute "Remote Installation" from "optional" to "local only" based on a type of source media.
- I should allow to choose ADDSOURCE or ADDLOCAL if the installation is done from Administrative installation or from a CD immage.
- I should allow only ADDLOCAL if the installation runs from a CD directly.
Thanks a lot,
Galina
Conditionally change component attributes
Galina
, Oct 31 2007 15:15
Posted 31 October 2007 - 21:34
I understood that I need to check a condition when SourceDir is in a removable volume or CD ROM volume (didn't find DVD volume).
Who knows how to check it, pleeeeeeeese help!!!!!!
Posted 01 November 2007 - 11:08
If you build a release with compressed media (CABs) you should automatically get this functionality, as described in my article Custom Setup Options in Windows Installer
Posted 01 November 2007 - 13:46
Hi Stefan,
Thanks a lot for your answer.
I can not build a release with compressed media. The files on the CD should be accessible.
Is it possible to find if SourceDir is read-only or the files in SourceDir are read-only?
Galina
Galina
Posted 02 November 2007 - 01:33
Look at the function GetDriveType (a Win32 function, but InstallScript has a similar function) - it tells you whether a drive is a network drive, fixed disk, RAM disk, or removable disk.
