I'm having problems running two out of a series of applications within a install. These fail to run and report an error that "there are no child processes to wait for".
Has anyone else seen this error or have any idea how to solve this?
Thanks, Celia.
Problems running applications within an install
CPorter
, Feb 06 2003 18:16
Posted 06 February 2003 - 18:27
And yes, before you ask, these exes do run outside the install program.
Thanks, Celia.
Thanks, Celia.
Posted 06 February 2003 - 21:14
How are you calling these other installs? Through DoInstall or LaunchAppAndWait?
Posted 13 February 2003 - 12:38
I was using LaunchAppAndWait as the problem applications did not have an inx file.
However I found that the problem was solved if I did a ChangeDirectory to the directory in which the application exists and then ran it.
Thanks, Celia.
Thanks, Celia.
